TwinTurbo.NET: Nissan 300ZX forum - Since the display is going out too - sounds more like a
Subject Since the display is going out too - sounds more like a
Posted by jzack on June 23, 2008 at 4:49 PM
  This message has been viewed 122 times.
In Reply To A/C Problem posted by mfergus2000 on June 23, 2008 at 01:10 PM
Message loose connector or failing issue with the dash control pod.
Main idea here: Controller system has an intermitent connection break and the system stops working.
I'd check the control pod connector and maybe replace the control pod with a used one? If that doesn't do it -- there's connectors buried in the dash that go to the climate control system (much harder to get at).
This doesn't seem like an easy issue to troubleshoot.
PS - It also could be as simple as fuse loosing contact due to vibration and age. Another thing to a least glance over...
