| Message |
its better to have a higher producing alternator for your setup. Hopefully your system is installed properly with a decent ANL fuse for your amp power, perhaps a decent cap if youre constantly bumping the system, and a good battery (Optima Yellow works for my 880Watter). New terminals, new ground to firewall (and tranny if you have some time), grounding net to have a bulletproof powered system. make sure your PS system is tight with no leaks. check it before and after alternator install, you can even cause a problem when installing it, hoses are right there and its easy to bang on. leaky PS system = alternator killer
