TwinTurbo.NET: Nissan 300ZX forum - Re: High voltage + gas = BOOM!
Subject Re: High voltage + gas = BOOM!
Posted by Gokussayien on June 23, 2008 at 8:11 AM
  This message has been viewed 117 times.
In Reply To High voltage + gas = BOOM! posted by na300zx (OH) on June 23, 2008 at 05:17 AM
Message Dude listen for all the trouble your going through trying to repair a damaged injector you would be so much off buying a brand new set of injectors. Everybody is a Z owner will tell that shortcuts like this usually bite you in the azz hard in the end. If you cant fix the injector and it malfunctions while your at high rev I will be able to see your motor go sky born from here. But if you were inerested in buying some used injectors ill sell you a set of 93tt fuel rail and injectors for $75.00 bucks its a steal and a upgrade. But let me know.
