TwinTurbo.NET: Nissan 300ZX forum - Re: Boost Problems
Subject Re: Boost Problems
Posted by Gokussayien on June 23, 2008 at 7:54 AM
  This message has been viewed 133 times.
In Reply To Boost Problems posted by Jtrex on June 22, 2008 at 09:11 PM
Message Also I almost forgot to tell you, it is very important and critical that you check the maf(mass airflow sensor)by making sure it does not have a loose clamp holding it in or a bad harness connection. This is critical because it measures the amount of air coming in to the motor and adjust the fuel to compensate for to much air or to less air. It could cause your car not to boost properly, I know this is a lot of stuff to check but you must if you want to make sure of things.
