TwinTurbo.NET: Nissan 300ZX forum - Re: Boost Problems
Subject Re: Boost Problems
Posted by Gokussayien on June 22, 2008 at 10:06 PM
  This message has been viewed 117 times.
In Reply To Boost Problems posted by Jtrex on June 22, 2008 at 09:11 PM
Message dude the best thing i can tell you on this one is check all vaccum lines. The easiest and most resposive way is get you a can of throttle body cleaner or carb cleaner and spray it all around the vaccum lines area. if you have a leak the motor will drop down on the idle a lot. Next make sure we have good connections on all injectors and coil packs also the wiring and harness that goes with those. No corrotion and no bad wires.
