TwinTurbo.NET: Nissan 300ZX forum - You connect an air compressor to one end of the rail
Subject You connect an air compressor to one end of the rail
Posted by ThunderZ on June 21, 2008 at 3:40 PM
  This message has been viewed 171 times.
In Reply To I installed a pressure gauge just past the filter, posted by ae300z on June 21, 2008 at 07:24 AM
Message and block off the other end. One end is where you connect the FPR and the other is the Dampner. Use an adjustable pressure control valve so you can check it from 40-60 psi.
It should hold the pressure. Use a stethoscope to hear any leaks.
I 2nd what aliaZ said also.
