TwinTurbo.NET: Nissan 300ZX forum - I was about to assume the G20 has a McPherson strut up front
Subject I was about to assume the G20 has a McPherson strut up front
Posted by Ashman2k2 on June 20, 2008 at 1:50 PM
  This message has been viewed 114 times.
In Reply To 300 ZX Camber Shimming Technique OK for Infinity G20? posted by Thomas+10 on June 20, 2008 at 09:24 AM
Message but after a small google search it looks like identical to the z32 front. So the answer to your question would be yes, you should be able to shim out the upper arm to counter negative camber. On another note, you say you used just washers between the arm and the frame to space out the upper arm..I would recommend a solid bar in between instead. This way the load is distributed over a larger surface of the frame.
