TwinTurbo.NET: Nissan 300ZX forum - Connector identification
Subject Connector identification
Posted by BobbyT on June 20, 2008 at 3:19 AM
  This message has been viewed 255 times.
Message Did some engine bay cleanup involving a few of the connectors I'm not familiar with. The red circle in the pic is the line I moved (now buried up by the headlight assembly). The connector is mounted roughly where the red X is...on the inside of the strut tower, down and rearward of the power steering reservoir. It exits the engine bay toward the fender well...what is it?
Also, reloomed one of the bigger chunks of the wiring harness. It's about a 1-1.5" diameter loom coming from the PS pump area, leading to just behind the headlights under the green oval in my pic. There are 4 connectors, marked as black dots/rectangle.
Furthest inside (toward the center of the car) is a squarish connector with 1 or 2 blades. Then there's a big rectangular one with 8 or 10 pins. Then there are two very similar squarish ones to the outside, with one in front of the other (both have two pins). Last time I did connector cleaning I didn't hit these and the outer two were incredibly gunky. I'd love to know what all 4 are.
