JWT Sport 500 posted by street kingz on June 18, 2008 at 07:40 PM
I suggest you contact Ben Pila @ JWT. He was very helpful when I installed my Sport 500's and JWT ECU upgrade. This is what I learned: at 10psi the Sport 500's pump as much air as the stock turbos at 14psi. With stock injectors and the appropriate ECU upgrade (and no boost jets installed) you should disconnect the boost solenoids. This will cause the boost on the Sport 500's to be approximately 10psi (which is the max you should be running with the Sport 500's and stock injectors). This is what I did and it runs fine - a bit more power and a little bit more lag but no impact on gas mileage and I feel that I am not stressing the engine (however, it is appealling to add larger injectors and reconnect the solenoids but this would also require an ECU update and I plan on keeping the car for a long time!). I hope this helps.
