TwinTurbo.NET: Nissan 300ZX forum - what else is installed?
Subject what else is installed?
Posted by bliZard on June 19, 2008 at 8:24 AM
  This message has been viewed 163 times.
In Reply To 7 psi still! whats wrong? posted by tsaitang on June 19, 2008 at 07:03 AM
Message If you are sure the code is cleared from the ecu? I had to temporarily use the resistor for a failed sensor and learned that the car was still in safety mode because the code hadn't been cleared manually. Maybe it resets itself over time. I would check it again to make sure it hasn't come back.
I don't know if the 02 failure can cause safteyboost.
The fact that you are wanting 14psi means that you must not be stock - how are you achieving 14psi? boost jets? EBC? Has it ever run 14psi?
