TwinTurbo.NET: Nissan 300ZX forum - CTS is located on the hardpipe. Yellow connector.
Subject CTS is located on the hardpipe. Yellow connector.
Posted by Attila on June 18, 2008 at 1:45 PM
  This message has been viewed 231 times.
In Reply To Cylinder not working. Need help..advice Please! posted by 300z-shaat on June 18, 2008 at 08:58 AM
Hi,
CTS is located on the hardpipe. You need to find the yellow one, with 3 little connector inside. Clean it with connection grease or spray. Check for deformation. Switch off your A/C. If the connector is not on the right place or no connection your engine will idle at 1200 rpm and the A/C vent. will run. If the sensor work well, your idle is fine.
Regards, Attila
