TwinTurbo.NET: Nissan 300ZX forum - The only way to block it off while leaving it in is to cut
Subject The only way to block it off while leaving it in is to cut
Posted by doug8867 on June 18, 2008 at 1:03 PM
  This message has been viewed 294 times.
In Reply To what about a simple block off kit??? posted by Drk93TT on June 18, 2008 at 12:27 PM
Message the EGR tubes on either side of the plenum and then crimp/weld or plug them
shut, and then also put the blocking plates to cover the holes left on the
underside of the plenum where the tubes used to attach. You'll also need to
plug the small EGR vacuum hose on the passenger side too. IMO it will look
pretty ghetto with the tubes crimped shut, but to each their own.
