TwinTurbo.NET: Nissan 300ZX forum - Cylinder not working. Need help..advice Please!
Subject Cylinder not working. Need help..advice Please!
Posted by 300z-shaat on June 18, 2008 at 8:58 AM
  This message has been viewed 263 times.
Message Since I put everything back together after the plenum pull my car has been running on 5cyl. At 1st the passenger side middle cyl wasnt working..then somehow the next day it started to work and the driver side middle 1 stopped working. Maybe because I fiddled around with some connectors?
I tried cleaning all the connectors..including PTU.
I just pulled out the codes from the ECU and I got 2 codes..
13 : engine coolant temp. sensor circuit
53 : exhaust gas sensor circuit (right)
Could that be causing my car not running on all 6cyl?
Also my injector connectors are broken/lose and even after cleaning them theres still some green stuff in them..could the cyl not be working because of that aswell? ( I have ordered the new connectors,just waiting for it to be here )
I think the CTS is located on the hardpipe in the front, right?with the yellow connector?
But where is the exhaust gas sensor circuit located?Please if someone could tell me.
Thanks in advance and please someone help me sort my problem out because before the plenum pull my car was running perfectly fine..no hesitation or bubbling..just after sitting for almost a month without the plenum all this started to happen.
