| 1. replacing the head gaskets, do i need to plane the block? 2. what can i use to clean the rust and build up in the coolant pipes by hand (soaking)? Lime-a-way or something like that? 3.how do i clean all the rust coveing off of catalytic converter pipes to repaint with a rust protective or high temp spray paint? 4. what are some good replacvement hose clamps for the smaller hoses other than the OEM double ring "cheesy" clamps? something that won't "tear" into the rubber hoses.
