| Subject |
Re: Overheating Issue. |
| Posted by |
wilkendw on June 17, 2008 at 10:38 PM |
This message has been viewed 252 times. |
| In Reply To |
Overheating Issue. posted by Bohemiangod on June 17, 2008 at 09:38 PM |
| Message |
ebrake has switch, think it is under the brake boot I'd check the wire and test the switch with an ohm meter. Heat issue - test the continuity of the CHTS, make sure it is reading ok if so, probably just "global warming" heating up the hood, but just to be sure check the fan belt, fan clutch, and coolant level (always in morning when engine is cool). Antilock light is probably a brake fluid level issue start there and if it looks ok after bleeding the brakes etc, run codes to see if there is really a sensor problem of something else, I think if you paid a shop to do the job they should be willing to check it out for free...
| Follow Ups |
Post a Followup |
