TwinTurbo.NET: Nissan 300ZX forum - Just got done installing the test pipes
Subject Just got done installing the test pipes
Posted by NJBlack91TT on June 17, 2008 at 9:50 PM
  This message has been viewed 402 times.
Message And in the process deleted the AIV and the PRVR systems. All went well except for an unexpected sound coming from the down pipe/test pipe area. It's a mechanical, metalic sounds alsmost seems like you can here the turbo's work. It's higher pitched, and a little ennoying.
I checked all the nuts and botls on the test pipes, and they are very tight. I also used brand new gaskets on each end. I thought it might be air leaking out where the test pipe connects to the down pipe, but it's unlikely.
Does anyone have any idea if this is normal/expected?
The test pipes are Edge Racing 2.4" from CZP so are the gaskets. The catback exhaust is HKS Hi-Power, and the downpipes are Z1.
Thanks!!
