TwinTurbo.NET: Nissan 300ZX forum - well ... if it comes back, run codes again (n/m)
Guapo
on June 17, 2008 at 3:55 PM
NVM I'll still check the plugs but
posted by FuerGrissa
on June 17, 2008 at 03:32 PM
New det. sensor, sub-harness, EFI harness, ECU, same code34
FuerGrissa
11:46:17 06/17/08
No, wrong harness.
Woody75 (Denver)
12:29:14 06/17/08
I found the harness
FuerGrissa
13:22:17 06/17/08
That's the VTC harness...plug it in to where your DET sensor
twinturbineZ
13:28:26 06/17/08
Code 34 GONE, new problem...
FuerGrissa
13:54:41 06/17/08
Where did you plug the 02 harness into..pic please (n/m)
twinturbineZ
13:57:44 06/17/08
as requested (doh preview'ed and forgot to post)
FuerGrissa
14:24:02 06/17/08
your labelling appears correct (n/m)
Guapo
14:35:22 06/17/08
The part I have labled as "IAVC?" FSM says "air regulator"
FuerGrissa
14:41:05 06/17/08
yeah, I can't remember all the acronyms, but it is the
Guapo
14:58:06 06/17/08
The plugs were replaced about a month ago
FuerGrissa
15:21:32 06/17/08
FuerGrissa
15:32:54 06/17/08
well ... if it comes back, run codes again (n/m) -
Guapo
15:55:32 06/17/08
I found the harness, revision 1
FuerGrissa
13:25:35 06/17/08
There should be another group of plugs over toward the
twinturbineZ
12:56:41 06/17/08
