TwinTurbo.NET: Nissan 300ZX forum - 3 bar (43.5 psi) is correct at idle if you pull the vacuum
Subject 3 bar (43.5 psi) is correct at idle if you pull the vacuum
Posted by Guapo on June 17, 2008 at 3:15 PM
  This message has been viewed 329 times.
In Reply To High Fuel Pressure... posted by BrysZ on June 16, 2008 at 10:15 AM
Message line from the regulator. It should drop lower than that when vacuum is connected (at idle), and rise directly with vacuum/boost pressure.
It sounds like your new regulator is functional, but you need to make sure it is hooked up to it's vacuum source.
Petz #2
"What's the point of having the car if you don't drive it?" - Mrs. Guapo 08/20/05
Jeeeesus Christ - my Dad (after a ride in my Z) 12/26/04
People have the right to freedom of expression. However, people also have the right to point and laugh- aliaZ 04/06/06
