| Message |
I switched plugs for the VTC and DET sensor and its all code 55. I decided to double check timing since I was having trouble with it, and I wanted to make sure it didn't change after clearing the code 35. PTU wire is rock solid on 15BTDC, the #1 coil pack wire however will not even flash the gun AT ALL, and the check engine light keeps coming on intermittently. I think it must be misfiring? I had that coil pack off this morning to try and hook a spark plug wire between it and the plug to check timing, but I'll be damned if I could see anyway to attach the plug wire to either the plug (way down in a hole, or the coil connector which is just a little spring.) anyway I put it back how I found it and bolted it back down, now this >.<; How can I make sure it is not misfiring?
