| Message |
under Pages in the menu. I have had my Z for about 18 months, and this site is an invaluable resource, just skim through the FAQ and tech docs and check out the articles. There are some 3-4 pages full of FAQ topics, so sometimes it's tough to find what your looking for, but just keep scanning through each time you have a problem, or read about topics that interest you even if you don't have that problem! I've read the whole section a few times over and I still have to keep going back. Everything you need to take care of your car and be 95% self-sufficient in maintaining, diagnosing, and fixing problems with it are on those pages, so take advantage! Start with a thread by Ash's Z in the Vote to FAQ section called "The six P's, Proper preparation prevents piss poor performance" It explains exactly how to check your timing, compression, search for boost leaks, and check your fuel pressure. You should do all of those things as an initial inspection to make sure your Z is up to par, and each time you have a problem, start by taking those steps to figure it out, If one of those issues is not your problem then you will have eliminated many associated possible causes at the same time and give a better picture of what exactly is the problem.
