TwinTurbo.NET: Nissan 300ZX forum - Maybe the ethanol absorbs water making it conductive
Subject Maybe the ethanol absorbs water making it conductive
Posted by TTkeeper on June 16, 2008 at 12:32 AM
  This message has been viewed 149 times.
In Reply To I've seen both- replace 1 or 2 after 100k miles that break, posted by ThunderZ on June 15, 2008 at 09:01 AM
Message There is always a bit of condensation inside the fuel tank. Maybe the ethanol absorbs the water and makes the ethanol/gasoline blend somewhat conductive. Even if there is a constant 12v going to the injector, without the grounding signal from the ECU there isn't going to be any current flow.
The redesigned harness of the 95+ was probably for fire safety measures.
