TwinTurbo.NET: Nissan 300ZX forum - Re: 2nd on doing under the hood. Often the injector
Subject Re: 2nd on doing under the hood. Often the injector
Posted by Jenniferz300 on June 14, 2008 at 4:58 PM
  This message has been viewed 136 times.
In Reply To 2nd on doing under the hood. Often the injector posted by jzack on June 14, 2008 at 04:33 PM
Message :connectors have corrosion and a visual inspection is needed. Testing via the ECU won't tell you this and if the resistance readings aren't right -- you'll need to pull the connector anyway. In adddtion to the dental pick -- small needled nose pliers help too - makes it easy to grab the spring clip and pull it off.
Thanks Guys! I am going to give it a try... Your great!
