TwinTurbo.NET: Nissan 300ZX forum - 2nd on doing under the hood. Often the injector
Subject 2nd on doing under the hood. Often the injector
Posted by jzack on June 14, 2008 at 4:33 PM
  This message has been viewed 140 times.
In Reply To Under the dash on the passenger side. You unbolt posted by ThunderZ on June 14, 2008 at 03:43 PM
Message connectors have corrosion and a visual inspection is needed. Testing via the ECU won't tell you this and if the resistance readings aren't right -- you'll need to pull the connector anyway. In adddtion to the dental pick -- small needled nose pliers help too - makes it easy to grab the spring clip and pull it off.
