TwinTurbo.NET: Nissan 300ZX forum - Not sure I'm following the whole question.
Subject Not sure I'm following the whole question.
Posted by yobobrox on June 13, 2008 at 1:21 PM
  This message has been viewed 89 times.
In Reply To BOV question.. posted by onewheelf4 on June 13, 2008 at 11:37 AM
Message If you have some reason to think there is an issue with boost leak, you
should do a leak test. If you still have reason to believe there is a leak
even after a leak test has been confirmed to hold pressure, you should
go about eliminating any possible variables until you are either satisfied
that no leak exists or a leak is found. So, start with a leak test. If you
need help past that, feel free to ask.
Now, the safety rant:
You should always be using some sort of aftermarket boost gauge if the
boost is raised at all for safety reasons. It may or may not help in
identifying a leak (depends on the leak's size and your ability to notice a
change), but it will ensure you aren't overboosting the car and risking
lean conditions. Of course, a fuel pressure gauge is equally important
for safety. But, personally, I'd want a wideband O2 sensor (or two) as
well. That way you'll have a pretty good chance of catching any fuel and
air related issues before you toast the motor.
