TwinTurbo.NET: Nissan 300ZX forum - The resistor goes across the white and gray wires! (n/m)
twinturbineZ
on June 13, 2008 at 6:54 AM
On my connector I have three slots. I put the resistor
posted by Red300zxTT
on June 13, 2008 at 01:05 AM
Did Resistor bypass with knock sensor, worked for a while
Red300zxTT
16:33:16 06/12/08
maybe you have a fault in your harness? (n/m)
aliaZ
16:52:48 06/12/08
Soo i should trace the wire back to the ecu.
Red300zxTT
16:54:35 06/12/08
Or just check the wiring within a few inches of the
jzack
18:47:09 06/12/08
I traced it back a couple of inches from the connector
Red300zxTT
20:04:22 06/12/08
Buzzing the lines out for continuity would be the next
jzack
23:13:30 06/12/08
why not just fix it the correct way? (n/m)
eyagel
19:41:46 06/12/08
I agree! However...how did you connect the resistor
twinturbineZ
20:34:25 06/12/08
Red300zxTT
01:05:31 06/13/08
there should only be 2 slots on that connector
cossiemodo2000
02:50:16 06/13/08
3slots... with red, black and white wires ?
Dark Diver
06:19:34 06/13/08
That's correct! (n/m)
twinturbineZ
06:53:51 06/13/08
The resistor goes across the white and gray wires! (n/m) -
twinturbineZ
06:54:36 06/13/08
KK kool thanks man! (n/m)
Red300zxTT
10:59:16 06/13/08
