TwinTurbo.NET: Nissan 300ZX forum - more than likely its PTU wiring..
Subject more than likely its PTU wiring..
Posted by Mike87T on June 12, 2008 at 8:24 AM
  This message has been viewed 110 times.
In Reply To dead middle cylinders ? posted by Jenniferz300 on June 11, 2008 at 08:34 PM
Message unplug the 2 connections from the ptu, clean them up and use some dielectric grease on connection. Do the same for all of the adapters leading to the PTU as well as the CAS. I has this same problem and it ended it once dielectric grease was used. If this doesn't fix it, I bet its dead injectors.
