TwinTurbo.NET: Nissan 300ZX forum - I've used both NA & TT plastic gears on TT speed sensors
Subject I've used both NA & TT plastic gears on TT speed sensors
Posted by Bernie (NoVA) on June 12, 2008 at 2:19 AM
  This message has been viewed 152 times.
In Reply To Na speed sensor with blue TT gear posted by BlackTT91 on June 08, 2008 at 11:49 PM
Message that works ok - however I think you may have the same issue that Spdracer is talking about if you go the other way...
When you have the gears side by side you can notice that the shaft that is molded on them is a bit different lenght. You may be able to trim or shim the TT gear as needed to adjust the fit.
Bernie
