TwinTurbo.NET: Nissan 300ZX forum - Turbo oil line bolts into the block
Subject Turbo oil line bolts into the block
Posted by jrose10392 on June 11, 2008 at 9:09 PM
  This message has been viewed 184 times.
Message If you examine both bolts that attach to the block from the turbo oil lines they are different. The drivers side is wide open and not restricted where the passenger side in comparison looks to be a pin hole. My question is why? I recently had turbo problems and found the drivers side had an oil starvation issue. These were previously installed proper location and I'm looking for anything as to why. Is the reasoning behind this because of the distance the oil has to travel from the block to the turbo's? I'm just curious as to why?
  • Turbo oil line bolts into the block - jrose10392 21:09:21 06/11/08
