TwinTurbo.NET: Nissan 300ZX forum - Re: Take the harnesses off the fuel injectors
Subject Re: Take the harnesses off the fuel injectors
Posted by Jenniferz300 on June 11, 2008 at 9:05 PM
  This message has been viewed 108 times.
In Reply To Take the harnesses off the fuel injectors posted by 300ZMang on June 11, 2008 at 08:47 PM
Message :ohm test them with a multimeter after cleaning any green crap off. They s/b 10-14 ohms, anything else is no good.
:Also clean your PTU harness and CAS as well.
:I'd say you need new injectors tho, search for dremel method if you don't wanna do a plenum pull
Thanks much for the info here... I will try this... your a great help 300zmang
