TwinTurbo.NET: Nissan 300ZX forum - The one right to the left of the oil fill cap correct?
FuerGrissa
on June 11, 2008 at 4:05 PM
Re: Picture
posted by PhilupondZ
on June 11, 2008 at 02:36 PM
Without intimate knowlege or the ability to see under the connector I suppose I could have been on the injector wire rather than the coil pack, but I dont think so.
CAS Adjustment (can I hit it?)
FuerGrissa
12:36:52 06/11/08
FuerGrissa
13:09:04 06/11/08
It's hard to tell from the photo. Those black lines
Audioquest
13:26:52 06/11/08
They look black in the picture, but in person they are red
FuerGrissa
13:40:15 06/11/08
Re: Picture
PhilupondZ
14:36:14 06/11/08
The one right to the left of the oil fill cap correct? -
FuerGrissa
16:05:56 06/11/08
Same thing happened to me when I removed the 3....
Marc (NJ)
15:34:57 06/11/08
Re: Same thing happened to me when I removed the 3....
FuerGrissa
16:02:52 06/11/08
Remove driver side intake pipe and if you have small....
Marc (NJ)
18:03:20 06/11/08
You didnt even have to remove the radiator hoses? (n/m)
FuerGrissa
19:38:33 06/11/08
Re: You didnt even have to remove the radiator hoses?
Marc (NJ)
20:26:40 06/11/08
FYI: The mounting bracket that the CAS bolts down to can be
jzack
20:23:43 06/11/08
Thanks!, CAS Bracket wass off at dealer 2 weeks ago so
FuerGrissa
21:36:11 06/11/08
You can tap on it to get it to turn. It won't hurt anything.
Woody75 (Denver)
16:03:49 06/11/08
You mean flip it over on the same wire? (n/m)
FuerGrissa
19:40:47 06/11/08
Use the black loop on the PTU harness
300ZMang
20:22:31 06/11/08
location of PTU harness? use dummy terms please >.> (n/m)
FuerGrissa
21:31:39 06/11/08
Black box w/ 7-8 wires on passenger timing belt cover (n/m)
BobbyT
22:04:51 06/11/08
I got mixed results
FuerGrissa
09:47:29 06/12/08
Yes, flip it over on the same wire. (n/m)
Woody75 (Denver)
10:44:10 06/12/08
the #1 plug wire gives same result both ways, the PTU
FuerGrissa
12:28:55 06/12/08
