TwinTurbo.NET: Nissan 300ZX forum - how do you know if a cylinder is firing?
Subject how do you know if a cylinder is firing?
Posted by Jaskozx on June 11, 2008 at 2:46 PM
  This message has been viewed 153 times.
Message If its not could the problem be the ignition coil wire, or the wire that goes to the fuel injector, because when I take the wire out the ignition coil there is no difference in idling. and how do you check if the fuel injector is working?
