TwinTurbo.NET: Nissan 300ZX forum - Sounds like somethings fried in the ECU...There is
Subject Sounds like somethings fried in the ECU...There is
Posted by twinturbineZ on June 11, 2008 at 12:29 AM
  This message has been viewed 147 times.
In Reply To Re: Did you check the fuses by the battery?? Also is the posted by tlmaniac on June 10, 2008 at 05:25 PM
Message an orange wire from the ECU which supplies ground to trigger both those relays and allow power to the coils and injectors...You could try grounding the orange wire and see if the car starts..it probably will and will shut off once the ground is removed. The 2 smaller wires should be grounded through the ECU once the key is turned on..to allow the car to start...
So I'm having this dream! I'm in my Z and these guys are after me, but they can't catch me...So they get a car, but they still can't catch me. So they get a plane, and just as their about to catch me....the TWIN TURBOS KICK IN!
