TwinTurbo.NET: Nissan 300ZX forum - Are you able to keep the car running by applying gas pedal?
doug8867
on June 10, 2008 at 10:03 PM
injectors replaced-- car won't start
posted by jm12rr
on June 10, 2008 at 09:41 PM
If so, then you've got a vacuum leak and likely from the plenum gasket.
jm12rr
21:41:42 06/10/08
White cloth sheath is VTC (n/m)
twinturbineZ
22:02:51 06/10/08
Re: White cloth sheath is VTC
jm12rr
22:29:01 06/10/08
DET sensor has gray and white wires on harness side
twinturbineZ
22:45:16 06/10/08
Re: DET sensor has gray and white wires on harness side
jm12rr
22:55:19 06/10/08
Are you able to keep the car running by applying gas pedal? -
doug8867
22:03:51 06/10/08
Re: Are you able to keep the car running by applying gas ped
jm12rr
22:14:57 06/10/08
Yeah it could be other things especially if you are hearing
doug8867
22:28:58 06/10/08
Re: Yeah it could be other things especially if you are hear
jm12rr
22:37:10 06/10/08
