| Subject |
Re: Re: Okay, grey smoking is still there... |
| Posted by |
se7en_ on June 10, 2008 at 1:22 PM |
This message has been viewed 98 times. |
| In Reply To |
Re: Okay, grey smoking is still there... posted by towlett (Rochester, NY) on June 10, 2008 at 08:16 AM |
| Message |
:Second Alex's comment. Also, I had grey smoke and very black exhaust tips on my car, could also smell gas in the oil when changing it. I was advised that didn't mean it was nessesarily running pig rich, I would have to get it on a dyno with a wideband O2 sensor to know for sure. :Well, I haven't done that yet, but I did delete the EGR and AIV's and the assoiated solenoids and vacuum lines. Cleaned up the engine bay and ditched a rats nest of vacuum lines with tees. I just got back from over 10 hours of traveling and the tips are not blackened at all, and I don't see the grey smoke at idle anymore. :Boost leak test, boost leaks will make the car run rich, that may be your issue. I did a boost leak test myself and it checked out okay, as far as I could tell, so I suspect there were many small leaks in several places in amongst the many lines and tee's that I removed. :Ya, mine has all the delete's done to it also... I will have to do a boost test...
Fast is a state of mind. |
| Follow Ups |
Post a Followup |
