TwinTurbo.NET: Nissan 300ZX forum - Check engine light stays off = no codes?
Subject Check engine light stays off = no codes?
Posted by FuerGrissa on June 10, 2008 at 11:54 AM
  This message has been viewed 212 times.
In Reply To It saves codes forever till cleared, pause between codes. posted by Fast300 on June 09, 2008 at 10:01 PM
Message I used the method of shorting the pins on the connector near the hood release, I had the car ON, but engine not started so all the dash lights were on, as soon as I shorted the two pins the check engine light went off, I held it there for 3-5 seconds and the check engine light did not come back on till about a second after I stopped shorting the pins, once on it didn't blink at all.
Does this mean there were no codes? and if there is no code that means that it has never detonated under 3500rpm?
