TwinTurbo.NET: Nissan 300ZX forum - Re: Okay, grey smoking is still there...
Subject Re: Okay, grey smoking is still there...
Posted by towlett (Rochester, NY) on June 10, 2008 at 8:16 AM
  This message has been viewed 97 times.
In Reply To Okay, grey smoking is still there... posted by se7en_ on June 10, 2008 at 12:36 AM
Message Second Alex's comment. Also, I had grey smoke and very black exhaust tips on my car, could also smell gas in the oil when changing it. I was advised that didn't mean it was nessesarily running pig rich, I would have to get it on a dyno with a wideband O2 sensor to know for sure.
Well, I haven't done that yet, but I did delete the EGR and AIV's and the assoiated solenoids and vacuum lines. Cleaned up the engine bay and ditched a rats nest of vacuum lines with tees. I just got back from over 10 hours of traveling and the tips are not blackened at all, and I don't see the grey smoke at idle anymore.
Boost leak test, boost leaks will make the car run rich, that may be your issue. I did a boost leak test myself and it checked out okay, as far as I could tell, so I suspect there were many small leaks in several places in amongst the many lines and tee's that I removed.
From 300ZX TT Road...
