TwinTurbo.NET: Nissan 300ZX forum - Re: Stock boost is 9.5 PSI how do you get that with Z1 GT525
FuerGrissa
on June 09, 2008 at 10:02 PM
Stock boost is 9.5 PSI how do you get that with Z1 GT525's? (n/m)
posted by Fast300
on June 09, 2008 at 09:57 PM
I'm not sure I understand that, but I was under the impression that turning off the electronic boost controller (holding in select for 2 secconds on the greddy unit) puts you back at stock boost (9.5 psi)
in what order would you investigate the source of detonation
FuerGrissa
21:27:53 06/09/08
You can run codes without a reader ...
Guapo
21:45:17 06/09/08
Thanks, I had read that but wasn't sure I understood
FuerGrissa
21:55:45 06/09/08
It saves codes forever till cleared, pause between codes.
Fast300
22:01:30 06/09/08
Thanks, I'm always scared of getting in over my head,
FuerGrissa
22:03:53 06/09/08
Naa, that is what this forum is for, to help. (n/m)
Fast300
22:14:59 06/09/08
Check engine light stays off = no codes?
FuerGrissa
11:54:51 06/10/08
Fast300
21:57:42 06/09/08
Re: Stock boost is 9.5 PSI how do you get that with Z1 GT525 -
FuerGrissa
22:02:12 06/09/08
That is with turbos that have stock activators
Fast300
22:12:43 06/09/08
agreed (n/m)
Guapo
22:18:07 06/09/08
I'd Like to get larger injectors down the road, but
FuerGrissa
22:22:44 06/09/08
Oh no, 14 psi with STOCK turbos, not GT525's (n/m)
Fast300
22:38:17 06/09/08
2nd. At 14 psi, the GT525's flow much more air.
MixManMash
15:15:23 06/10/08
I am not runing lean,FuerGrissa has the problems not me. (n/m)
Fast300
15:40:56 06/10/08
I know that. I was merely commenting as an addition to your
MixManMash
16:45:31 06/10/08
