TwinTurbo.NET: Nissan 300ZX forum - What color was the smoke?
Subject What color was the smoke?
Posted by doug8867 on June 09, 2008 at 12:45 PM
  This message has been viewed 128 times.
In Reply To Plenum pull, PCV valve(s) replacement, and valve cover gaske posted by CaptainZappo on June 08, 2008 at 11:35 PM
Message Before you pull the plenum I'd make sure you've identified where the
smoke is coming from. If it's coming from a turbo or exhaust leak then
pulling the plenum won't help you fix it.
However, If you decide to pull the plenum,review the tutorial in the FAQ>
AutoFAQ by Nytwolf if you haven't already. If you decide to do it, you need
to allow 12 to 14 hours over a couple days doing it your first time. Valve
covers will add another 2 or so hours the first time. Getting the exhaust
covers off sometimes is tricky to get them to clear the EGR tube.
Also replace the rear and side PCV hoses as well as the AAC air hose
too, and coolant/fuel hoses too so you can save time and simply cut the
old ones off.
Make notes, label things, and take pics if you need to help you remember
where things go.
Essential tools needed: Long 45° needle nose pliers for getting to hose
clamps in awkward positions, 10mm, 12mm, 14mm socket and ratchet
(10mm nutdriver helps speed things up), 8mm gear wrench flex head
ratcheting wrench for removing EGR bolts, Phillips Head screw driver.
Good luck.
