TwinTurbo.NET: Nissan 300ZX forum - Re: Re: you're probably low on freon
Subject Re: Re: you're probably low on freon
Posted by aliaZ on June 09, 2008 at 12:36 PM
  This message has been viewed 119 times.
In Reply To Re: you're probably low on freon posted by Mike87T on June 09, 2008 at 11:32 AM
Message :no I haven't. I've done a lot with cars but have no experience with AC charging/troubleshooting. So if it is low on freon, the compressor won't engage when it should?
There is a pressure switch that will prevent compressor engagement if the freon is low
I know when it did work last summer, it didn't blow very cold, so maybe it is low. Should I recharge it?
That depends. Do you have the skills and equipment to fix your leak and properly recharge it? Otherwise you may damage your system. Is it still R-12, or has it been converted to R-134a?
If so, could it be charged with pep boys/autozone stuff they sell now?
The retrofit kits sold at pep boys/autozone are crap imho. You need a license to buy R-12, and the R-134a retrofit kits they sell are a crapshoot. If I were you I'd take it to a shop. Otherwise, browse the forums at ackits.com and learn the right way to do it.
When I do a retrofit, I flush the old oil from the system and replace it with 8 ounces of POE lubricant, and then recharge with 2 cans of R-134a. You'll need the proper gauge set and a vacuum pump, both of which are available at autozone for free.
