TwinTurbo.NET: Nissan 300ZX forum - fuel pump blues.... still....
Subject fuel pump blues.... still....
Posted by nemo1080 (Iowa) on June 09, 2008 at 2:53 AM
  This message has been viewed 133 times.
Message ok so the fuel pump is not coming on with the ignition switch. the pump is good, and so is the controller. if u hardwire the pump it comes on, and the controller has been swapped out with a known working one, and still no change. the relay was even swapped out, with a known working one, and still no change. the fuse under the hood is good aswell, and all cabin fuses are in order. to make it worse, sometimes the pump will come on, after we hard wire it, it will run on its own. and sometimes it won't work unless hardwired.
let me know if u have any idea whats up.
car is a 95 TT swap auto
It's not turbo lag, It's foreplay! Click Sig for My local forum!
" A Z was stolen But apparently to everyone here it's more important that the D key is not to the E key and she missed.
Do you people have souls? Seriously, this is pretty fucked up."
- Pacmanpth
