TwinTurbo.NET: Nissan 300ZX forum - HubCentric Rings
Subject HubCentric Rings
Posted by sandplasma on June 07, 2008 at 11:13 AM
  This message has been viewed 148 times.
Message I have an aftermarket set of wheels with the following specifications:
Front: 18x8.5 ET25 HB 73
Rear: 18x9.5 ET28 HB 67.1
I know that the Hub Bore for the Z32 is 66mm..and the fronts did come with a hubcentric rings that make them 67.1mm as well.
Would it be ok if I used the 67.1 rings and installed the wheels on the car? Or is that small difference of 1.1mm going to still cause vibrations?
Thanks guys.
