TwinTurbo.NET: Nissan 300ZX forum - With a TT flywheel, and a TT tranny, the mounting....
Subject With a TT flywheel, and a TT tranny, the mounting....
Posted by zeeway on June 07, 2008 at 5:30 AM
  This message has been viewed 77 times.
In Reply To 5 spd conversion posted by TurboZboy on June 06, 2008 at 06:00 PM
Message boss for the starter is in the correct place in space for the starter to engage the flywheel correctly - both starters are the same. Check you starter mounting - if it is correct, I would suspect your problem may be with the starter solenoid that causes engagement with the flywheel teeth.
____________________________________________________
__zeeway__
