TwinTurbo.NET: Nissan 300ZX forum - i got the one with a tire valve attached because i
keffboyer2000
on June 06, 2008 at 8:03 PM
everything i have seen says 5psi MAX (n/m)
posted by 600ZXR
on June 06, 2008 at 07:21 PM
dont have access to a air compresser. so will be pumping air through a regular old tire pump.
just got boost leak tester in mail have question about
keffboyer2000
19:18:53 06/06/08
I think about 5 psi..it should bleed off slowly through
twinturbineZ
19:21:34 06/06/08
600ZXR
19:21:46 06/06/08
i got the one with a tire valve attached because i -
keffboyer2000
20:03:16 06/06/08
That might take forever. Might want to pick up a
ShakaShaun(Denver)
20:54:59 06/06/08
really will it take that long well i guess i can have
keffboyer2000
21:09:52 06/06/08
tried that, didnt work. gave up. actually
aidemsined (to)
00:35:41 06/07/08
With a N/A you must have a rough idle to suspect a
not4resaleZ
23:36:16 06/06/08
You need an air compressor. Unless you plug up the
Nissan GTR
08:07:27 06/08/08
