TwinTurbo.NET: Nissan 300ZX forum - voltage is right on spark is a nice blue. Sprayed fuel into
Subject voltage is right on spark is a nice blue. Sprayed fuel into
Posted by 600ZXR on June 05, 2008 at 11:12 PM
  This message has been viewed 170 times.
In Reply To That might be the problem! CHECK YOUR VOLTAGE posted by twinturbineZ on June 05, 2008 at 02:12 PM
Message the intake and it fired right up. I took off the cas and turned it by hand, i get a hissing/gurgling sound from the fpr but no injector clicks. I put on a fuel pressure gauge and it read fine. i checked for power to the injector plugs, they read from 4.5v to 6v. When i check the ohms on the injectors they read anywhere from 10 to 15 for an instant then it drops quickly down to zero. My multimeter is a cheap one from harbor frieght tools so i am asking if my injectors are bad or is my meter bad?
