TwinTurbo.NET: Nissan 300ZX forum - Boost control install
Subject Boost control install
Posted by RedTTZ91(OK) on June 05, 2008 at 8:09 PM
  This message has been viewed 135 times.
Message Off of thumpers sight. It says remove the lines going from the stock wastegate to the nipples on the intrercooler pipes THAT LEAD TO THE THROTTLE BODY. But i thought the line went straight from the intercooler pipe to the wastegate? What is it talkin about it runs to the throttle body also? Read below its from his page
The wastegate vacuum hoses are simple to reroute to the Greddy control solenoid. Unplug stock wastegate hoses connected to nipples on the intercooler pipes that lead to the Throttle Bodies. Once disconnected, take a long length of 1/4" hose, connect to one side, run around the side of the radiator and around the front, then around the other side back toward the engine, and connect to the other nipple. Cut the loop in half in front of the radiator, use a 1/4" 'T' and connect the ends you just cut. Then run a short line down to the NO port on the Greddy control solenoid.
