TwinTurbo.NET: Nissan 300ZX forum - i dont need a correct afr right now just making sure it
600ZXR
on June 05, 2008 at 1:49 PM
Re: Trial start = no start
posted by wilkendw
on June 05, 2008 at 12:41 PM
starts before i put the whole thing together. if it will fire and run for 5 seconds that is good enough.
600ZXR
09:54:00 06/05/08
wilkendw
12:41:13 06/05/08
i dont need a correct afr right now just making sure it -
600ZXR
13:49:06 06/05/08
Should still at least start up and idle off the
twinturbineZ
13:47:58 06/05/08
yes it just cranks over and over once in a while i get a
600ZXR
13:51:07 06/05/08
Check the CAS..your timing might be off..are
twinturbineZ
13:54:31 06/05/08
not a fat blue spark more like a little white one
600ZXR
14:03:02 06/05/08
That might be the problem! CHECK YOUR VOLTAGE
twinturbineZ
14:12:36 06/05/08
voltage is right on spark is a nice blue. Sprayed fuel into
600ZXR
23:12:11 06/05/08
So the injector are not firing?? I think the
twinturbineZ
17:33:03 06/06/08
One other thing...and do this very carefully
twinturbineZ
13:56:38 06/05/08
