TwinTurbo.NET: Nissan 300ZX forum - Re: misfire on cylinders #1 and #2...
Subject Re: misfire on cylinders #1 and #2...
Posted by Mike87T on June 05, 2008 at 11:23 AM
  This message has been viewed 368 times.
In Reply To misfire on cylinders #1 and #2... posted by rmm299 on June 05, 2008 at 10:47 AM
Message YES the PTU being bad can cause problems on just those two cylinders. And as far as the gas smell, I have had injectors stuck open before and dumping gas in, so the spark is unable to ignite the massive amounts of gas. This resulted in a strong gas smell like you described. Also, if you think about it, if the PTU is causing sparking issues on those two cylinders, it would mean the injector is still injecting gas, but nothing is sparking consistently to burn it,so the plugs would be wet with gas. So I'd do PTU first.
