TwinTurbo.NET: Nissan 300ZX forum - check the terminal connectors thoroughly, I had the exact
Subject check the terminal connectors thoroughly, I had the exact
Posted by rmm299 on June 05, 2008 at 11:06 AM
  This message has been viewed 85 times.
In Reply To power problems posted by allablur on June 05, 2008 at 08:37 AM
Message same problem a couple months ago and found a hairline crack in the positive battery terminal connector, replaced it, and the charging system was fine thereafter. If that doesn't fix it take a look at the fusible link box (small black rectangular box in front of the battery on the passenger side) and make sure that the wiring is in tact. These are the only other things that I can think of to help. Good luck.
