| Here is the situation...Im swapping my 91 automatic twin turbo to 5spd using a NON turbo transmission. Do i need to change any speed sensors? If so what ones and do i need TT spec or NA spec sensors? Also as far as the driveshaft goes what do i need, i have my TT automatic and a NA 5spd one. Bernie said these wouldnt work so i need the front and back of a TT 5spd drive shaft right. If i get just the front half would it need to be rebalanced? If i do a 1 piece will it need to be custom since its a auto>5spd swap with NA tranny. Arent the splines different on the driveshafts? So wouldnt i need a NA front half and TT rear? Sorry for all the questions these are just the last few things i need before i start and im a little confused with using the NA transmission. Thanks
