TwinTurbo.NET: Nissan 300ZX forum - Could it be a shorted relay, or am I going to end up
Subject Could it be a shorted relay, or am I going to end up
Posted by JumWilmZ(AZ) on June 04, 2008 at 6:13 PM
  This message has been viewed 132 times.
Message checking the entire harness for shorts?
I'm still having the blown Clearance/Illumi fuse issue.
1. I've removed every piece of hardware attached to the harness (That I know of), and inspected the wires visually noticing no problems.
2. I've tested the plugs on the harness for continuity.
(Some tested as open, others with some resistance...none shorted completely)
3. I've checked the interior connections to make sure they all are in good shape, and they are.
I'm at a loss for what to check next.
So, I have a few questions to ask, hopefully you guys and gals have some answers to help me out.
Can relays short in a way that would cause this?
Where are the relays on this circuit, if any?
How do you check a relay?
What area/page of the service manual is the schematic for this circuit?
Thanks in advance!
